I have my camera mounted up high and would like to know if there’s a way to set the default tilt position more down than the factory setting of straight out.
Have you tried setting a waypoint?
Below is the manual if you need additional help.
I did that and it stays pointed where I set it but if I turn off the Pan scan it defaults back to the level position showing Mostly ceiling due to it being mounted on a bookshelf.
You can do one of two things:
Set Pan Scan with a single waypoint where you want it. It will stay there.
Set a Detection Zone pointing where you want it. It should return to that position.
That worked! Thank you so much.
