Is there any way from a computer or app to see the currently logged-in devices or to receive login notifications? I believe one of my cameras may have been unlawfully accessed.
What makes you think your camera was accessed unlawfully?
If you are really concerned, you could reach out to Security@wyze.com.
If you haven’t already done it, you should change your password immediately and setup 2-factor authentication. You may have had a problem, but you won’t anymore after you do this.
Yes, I have already done that. I also emailed Security asking for my account to be reset and any devices be logged out.
Welcome to the Wyze User Community Forum @mkdixon0316!
Definately reach out to security as suggested above. After that, follow the link below to the Wishlist request that is asking for a feature in the app or web account portal to view all login device history or get notifications of new device logins. Vote for it at the top, drop some likes
on posts, and add your own reply at the bottom if you feel compelled:
