I have a Wyze Cam Pan. How do I set it’s home, the place it returns to after I scan around?
Select Camera → Advanced → Motor Controls → Reset Position
Welcome to the community, @bvic1776. Here are three ways to get your Pan to return to the same position.
Default: Camera moves back to home position after 15 seconds. This is 180° from the power port on the base
Detection zone: If you set a detection zone, the camera will return to the middle of that zone after 15 seconds
Pan Scan way point: Set one Pan Scan way point, and turn on Pan Scan. NOTE: If you turn on Pan Scan, your detection zone is disabled and motion detection reverts to full screen.
