Color bulb floods broadcast
Been using this bulbs like forever, but ~6mo or so I started to notice humongous traffic coming off the switch like TBs of data
After traffic inspection it turns our 2 out of my 12 lamps almost simultaneously start sending DHCP disc packets.
495721 2.707239 172.16.147.17 0.0.0.0 DHCP 350 DHCP Request - Transaction ID 0x2eb0e389
0000 ff ff ff ff ff ff 7c 78 b2 6c 35 41 08 00 45 00 …|x.l5A..E.
0010 01 50 16 ee 00 00 ff 11 64 8d ac 10 93 11 00 00 .P…d…
0020 00 00 00 44 00 43 01 3c 8b d7 01 01 06 00 2e b0 …D.C.<…
0030 e3 89 00 00 00 00 ac 10 93 11 00 00 00 00 00 00 …
0040 00 00 00 00 00 00 7c 78 b2 6c 35 41 00 00 00 00 …|x.l5A…
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0110 00 00 00 00 00 00 63 82 53 63 35 01 03 39 02 05 …c.Sc5..9..
0120 dc 37 04 01 03 1c 06 0c 0f 57 79 7a 65 20 42 75 .7…Wyze Bu
0130 6c 62 20 43 6f 6c 6f 72 ff 00 00 00 00 00 00 00 lb Color…
0140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
any ideas?
DHCP packets are tiny. You would need TONS of them to get any substantial amount of traffic. To reach your 379 GB of traffic with the maximum possible DHCP size would take 315 million packets - or for a 24 period, comes out to 3655 packets per second. I don’t think so. There is something else going on,
This is exactly what’s going on. I gain 2Gb in a matter of a minute
I’m not buying that you are getting thousands of DHCP packets per second. Something else going on.
2GB per minute comes out to over 260 Megabits / second. A 2.4 GHz WiFi can not support that data rate (by a long shot). So even if the camera was TRYING to send that many packets, the WiFi could not come close to supporting it. Note, assuming one WiFi access port, the WiFi limit would apply to ALL devices connected to that WiFi - not just the one camera.
As I said, something else is going on.
I’m not selling anything here…
2.4 Ghz is over 400Mbit/s easy
Who said it’s 2.4 Wyze Cam, while it’s a 5 Ghz Lamp
Anyway, looks like an undiscovered bug that is unlikely to get fixed
