Now the question. There are a lot of compression artifacts in these videos that I don’t see in others’ nighttime videos. Is there a setting to improve record quality?
Edit: These videos were taken off the SD card, and not downloaded over the network. The SD card is one purchased from Wyze along with the camera.
@MostlyHarmless42: Regarding the artifacts, if you are talking about the dark splotches that pop up all over the video, I also see those in my videos, but have noticed that some other videos shared here don’t have nearly as many. I talked with one of those posters and the only difference we found was that I was using Standard Definition (SD) recording and they were using High Definition (HD) recording. Perhaps you are also using SD?
I bought it this way after hearing about this particular meteor type – the idea of owning a piece of something 20 million years older than the Earth fascinated me.
I understand… I used to keep a small meteor in my pocket all the time… When things at work got hectic, (I used to work in IT, prior to retirement), I would pull it out and look at it. That tends to ground one very quickly when it comes to hectic things around you…
