I am new to the app and cameras. I had done the initial camera setup close to my main router in my home but once I mounted the cameras I connected a wifi signal extender. I cannot find a place in the app where I can check which wifi signal my cameras are connected to. Does anyone know the answer?
Camera Live View->Settings (gear icon at the top)->Device Info.
I did that but it does not let me change wifi or anything like that. Do i need to reset camera and reconnect to new network?
You can’t change the WiFi/ssid. You have to do setup again, but don’t delete the camera from your app. That preserves all your settings.
With my setup, I noticed that the router/extender with the strongest signal connects to my cam. (The extender and router use same SSID). You can turn off your cam and restart near the device you want to connect to. Stongest signal would make sense, Mesh Wifi would route the same way automatically unless you have a rule set up to do otherwise.
