No I didn’t. Rustoleum included the primer.
Good to know, thanks!
Outside of taking the 4 small screws out, did you do anything else to take the cover off? Mine won’t come apart.
Oh gosh, it’s been so long ago I forget but I think there are notches on the sides that require the cover to be pulled away from the mounting plate to get it started.
I got it figured out. After taking the 1st 4 screws out, you have to take the battery holder out and then there are 2 more sets of screws.
cover of lock is held in place by magnet…
