Suddenly not able to download the 12 second event clips. Says i have to go to settings to enable. I go to settings and select “add photos only.” Doesnt work. Anyone know what’s up?
Since you prefer not to say whether you are using iOS or Android it is ???
This is iOS, pick one of the three. I use limited access,
Thank you. That worked. It must have been that selection before. Dont know why it suddenly just quit working unless an update changed a default or something.
iOS changed it a while ago. Before you could mark “Selected Photos” then after an app update a year or so ago you had to give access to all. The latest version of iOS changed it to limited. Freaking nuts.
