Soooo I can’t find WiFi settings in the app.
I hope I’m just blind and I don’t actually have to go to every single camera and re-set them up just because I changed my WiFi password because that would be kind of ridiculous…
Unfortunately, you are right. The only way at present to change a camera’s wifi setting is to run through the setup process on the camera.
You will probably want to go to the link below and vote for it. Make sure to click the VOTE button at the top:
A post was merged into an existing topic: Change Wifi Network Name (SSID) without resetting camera
