Will Wyze Band work properly if the display is worn inside the wrist versus the normal outside wrist?
Welcome to the Wyze community @dypark!
The band should work fine. There shouldn’t be any issues with the sensors or microphones on it. It may be harder to put on, but that’s my opinion.
The only issue that is possible is the raise to wake feature may cause the band to turn on by accident. You can turn this off in settings.
https://wyzelabs.zendesk.com/hc/en-us/articles/360038987872-How-do-I-set-up-my-Wyze-Band-to-wake-up-when-I-raise-my-wrist-
