Camera Position
I can’t get my camera to stay in the position I want. I’ve followed the support doc; resetting its position, resetting the camera. It doesn’t stay put! How do I get it stay pointing downward (the unit is positioned upside down affixed to the patio ceiling).
Video: iCloud
Detection zone turned on?
I’ve noticed that, with the Pan Cam, when a Detection zone is ON, wherever the cam is current set, this becomes the pre-defined spot. Then, if you adjust the view of the camera later, after 15 seconds it will move back to that location set up in Detection zone.
Just a thought…
Yes that was it! I adjusted the detection zone and now it seems to be behaving. Thank you!
