Camera connection 2.4 ghz to 5ghz
I was able to connect both of my camera to the 5 g network. You will need to change your phone from the 5 g mode and set it to LTE before you setup your camera.
Both of my cameras are working perfect. Hope this tip will help anyone trying to setup. Good Luck
You’re mixing up two different things here; the 5G (generation, mostly) phone network, and the 5ghz WiFi band.
Sorry for the mix messages. You are right on the term 5G is for the network is different to the 5ghz wifi band.
No worries. I make mistakes all the time. I only pointed it out to avoid confusion.
