Cam4 and Solar
For 3 years my WVOD is outside and powered by a solar panel I bought from Wyze. Works fine. I’m thinking about buying the new Cam4. Will my present solar panel work with the new Cam4?
The Cam V4 is powered by cable only and not battery. The Solar Panel will not work with it. However, the Battery Cam Pro does work with the Solar Panel. It also has a removable battery.
If you are looking at replacing a Wyze Cam Outdoor, I would seriously consider the Battery Cam Pro.
Thank you.
