Is cam plus subscription per camera or is it for all your cameras?
per Camera.
They have a $99 for 99 camera option when you pay a year in advance. Here is a topic where a member provided the links:
However, if you don’t want to pay this, then one camera will cost 1.25 per month per year - when you pay a year in advance.
use the Wyze site to buy it, I have had luck this way.
Thank you for the info.
Just to clarify, the standard subscription for CamPlus is per camera.
Thanks for the info.
And make sure you are logged on with the same User ID your cameras use before you place the other.
