Has Cam Plus Lite been discontinued? All my cameras are now only taking photos instead of video. I’ve reconnected all of the cameras and that didn’t work. They’ve all been updated.
Nope…working fine for me
Same here. Working fine tonight.
You cannot set up new accounts however if you have an existing account you can add unlimited v3 or prior cameras to it. You just need to go into your subscriptions and make sure the cams are associated with the subscription. Sometimes that association gets lost.
If they’re associated, try the “reset services” on each cam, but it is more likely to be the subscription linking thing.
You saved my mental health Dave! Thank you, this worked!
Haven’t had the “subscription association lost” problem in years but it just happened to all my cameras. Hope this doesn’t keep happening.
