Just tried to sign up for Cam Plus Lite and it wanted more money than I offered. You can’t get it free either, Not sure what I’m suppose to put in upper right box.
How did you try to access it? It used to act differently in the Wyze App store tab as opposed to the online.
You should be able to go to services.wyze.com thru your browser and sign up. The $0 option, regardless of what they suggest or ask, should be on the bottom or you should be able to fill in $0 in the “other” amount.
It has been so long since I signed up that it has probably changed by now.
