Cam OG. On the app. I see an event. I select the Go To SD Card. I play the event. But. I can not move forward or backwards through the event. In other terms, there is no way to scroll through the clip. What is going on here? Am I missing something or is this a lapse in engineering the app? Please advise. Thank you.
Are you trying to scroll through the SD card footage, or the cloud event? Can you post a screen shot of what your seeing? Are you getting cloud video events, or only a still image?
What actual version of the app are you using?
Are you looking for this? Unfortunately there isn’t one when playing OG SD clips.
