how can i move 1 group to another…when i try to add all other cams are greyed out when i go to
how many cams in group
thnx
thnx
You need to do it in 2 steps; delete from group, then add to a group.
Delete from a group:
Open group → Tap gear icon on top right → Tap arrow on line “Cameras in Group” → Tap the red “minus” icon of the camera to be removed from group
Add to group:
Same procedure, except you’ll select from bottom list of cameras available to be added.
wont that delete cam? will i have to go to the prop and reinstall cam?
tnx
No, it won’t
will do…
ty
