Anyone have any ideas on sensitivity? I have mine set on “1” and even someone’s shadow from sun sets it off and I get alerts. Headlights on ground, especially on wet pavement causes alerts. My driveway is small so I have it blocked out quite a bit, but it’s almost not worth having notifications on. Might as well not be a sensitivity setting if it doesn’t operate correctly.
The cam detects motion by pixel changes, so headlights will cause a lot of pixels to change. Try enabled motion tagging so you can see the green box around the motion that triggered it.
Use person only and set sensitivity at 60
