C wire adapter wiring
I can’t seem to figure out where to put the c wire for the adapter. Suggestions? I read a thread very similar but I couldn’t figure out how to implement the solution
C wire should connect to the Common connector the light yellowish wired is connected there.
Are you sure you need it? Do you have any extra Wires at the T-Stat coiled up, and in the HVAC?
