I know the bulb is not rated for continuous use in outdoor enclosed fixture. I would like to use it with Wyze contact when the garage opens.
It will be in enclosed fixture but only on for 10 minutes or so to light up the side for Security reasons. Just curious. Thanks
Some people have them in their porch lights, I have one in the entryway inside , the bulb is inside a globe and is triggered on by a motion sensor and or a door , it only stays on a short time, as long as your fixture is not metal it should work just fine
Thank you
