I installed the Battery Cam Pro into the Wyze Bird Feeder, these two were purchased as a set. I find that the Camera Field of View will not cover the entire feeding area. It works great if the birds stay on the perch, but my Southern Birds don’t follow directions and tend to walk into the bird seed container and out of the field of view of the camera during their dinner. Is there another camera that would provide the full view or another mounting method?
I have many examples of only the tails of birds feeding.
A family member has a Bird Buddy and the experience is similar. They did release a wider angle camera for it, but it makes everything look further away so she preferred to switch back to the normal field of view. With such a short distance there’s only so much that can be done without severely distorting the image.
Welcome to the forum.
Thanks for sharing your findings.
Hopefully a member might have a possible solution.
I haven’t bought a birdfeeder, but have been thinking about it.
