There a lot off “Bird People” here (Not me) . You can post your videos to Captured on WYZE. If the videos files are are larger than 580MB you will need to put them on YouTube and attach a link.
I love my bird feeder. Unfortunately, I have my feeder on a pole and the raccoons have found it. I have to keep it empty right now.
I’ve had mine since launch. Same setup as yours. It has weathered well and like you said, I clean it every so often and that is it. Battery is good to go too. Solar panel keeps up well.
There should be an adapter cable that converts it from Micro-USB (female) to USB-C (male) in the box. Many people don’t realize what the cable is for and discard it I think.
If not, you can get the item below from Amazon… or something similar. You will have to “tape” or weatherproof the Micro-USB end of the solar panel that this will adapt for.
