Battery cam pro 5% warning
Is there a way to get a notice when the battery cam pro battery is less than 5%?
There is a low battery notification in the BCP settings under Settings > Notifications > Device Notifications > Low Battery. It is not recommended that you let the battery get that low. 15% - 20% is the best percentage range for recharging the battery.
Thank you !!
