Do you have any suggestions as to why the band is causing skin irritation? I’ve had this issue with the Fitbits and other bands that were out. I don’t wear the bands too tight but I don’t like the irritation. Also those blue lights that come from the bands sensors seem to hurt my wrist (not sure what those are) but I can feel it when they start to light up. The band is good but perhaps maybe a clip for the band would be great like Fitbit has.
Any suggestions in the meantime?
I noticed this silicon band was causing my skin under it to have a white residue like soap or dry toothpaste. I also noticed that it was rubbing a red mark on my wrist, and removing one layer of skin. I am now wearing it on a looser setting to see if that fixes the problem.
I did that too and I still get the irritation. I measure 3 inches around my wrist so it’s hard to find a setting on the band that works
I had to quit wearing the Wyze band because of it. My wrist turned red and some of the skin peeled off. Looked like a burn mark.
This happened to me. I was wearing it too tight. I loosened it up 1 notch and the issue went away. Results may vary.
Like I replied to you above, I did that and I still have the issue. The band itself causes no problems, it’s the sensors in the band that record the step (looks like a laser) that hurts my wrist.
I thought this was just me. It looked like a burn mark, even though it was painless. And the skin would peel. I thought it was just because I’m in my 40s now and getting old.
