Thanks, @StopICU33! I’m not sure why it wouldn’t show up for @alancohen.
Yep it’s a little weird not showing up. The band needs to be up to date as well.
See Release Notes
Wyze Band Firmware
1.0.7.96 (September 9, 2020)
- Added a Tool Box function that includes a Stopwatch and Flashlight
- Added the ability to decline a phone call from Wyze Band
- Optimized battery level calculation
@alancohen, Can you check the firmware on the band as @StopICU33 suggests? Perhaps it’s the band’s firmware that needs an update.
On the band screen, the three dots in the upper right hand corner. Under Device info the firmware info will be listed.
As @StopICU33 is saying both the app and firmware for the band need to be at the most current version for the toolbox to show up. They are out of beta and in the production app and firmware.
Thanks.
Timer would be great. Like a 15 min 30 min and 1 hour timers like count down
I would love to see a countdown timer added to the Tools. I was about to lay down for a nap without my phone. It’d be great to set a timer on the band.
Not sure if it should be oversimplified for setting the timer options or allow precise times? At worst I’d set 5 minute increments to scroll through and set.
Hey Wyze!
How about a timer? Maybe presets for 2, 5, 10, 15, 20 and 30 minutes?
if you go the preset route, maybe the app allows you to configure what the time allotments are for the certain number of presets available.
I am very disappointed that the band does not have a countdown timer especially because from its description it sounded like it did, and that was my biggest reason for buying from Wyze. I just want a countdown timer, but for some odd reason it is SO hard to find a watch with the function. Please please please add a countdown timer, Wyze. I am so tired of setting timers on my phone for my workouts, and I work out at different times day to day, so an alarm won’t work. Please, Wyze, I’m begging you
