Apple HomeKit Integration
Good point. My primary “need” for the HomeKit integration is outdoor lighting and the ability to use the cameras motion sensor to trigger automations.
I currently have about 30 accessories in HomeKit (thanks to HOOBS). I really like my cameras and would love to able to get the triggers working with them. The cameras work great in HK and turn off/on as part of scenes.
I just installed HOOBS, but am having trouble getting Wyze to run on it despite other products loading just fine. One issue is the two factor authentication I have turned on. How do I get that and HOOBS to play nicely? Do I have to turn off that feature? Also, which plugin are you using? The most popular one, “Wyze Connected Home” seems to only support plugs and nothing else. That true? Thanks for the help.
HomeKit is just simple and it works perfectly. If you integrate Wyze with Apple HomeKit I would definitely change all my smart devices to Wyze.
I just found a way to make it work (bulbs and plugs). All you need is a raspberry pi, a micro sd card and that’s it. Go to hoobs.org to check it out. They have a pricey system that works out of the box, but a simple raspberry pi 0 w for $20 works just as well.
I’m so happy to finally have Siri turn my lights off!
I got it all working. I spoke to a developer and got bulbs and plugs working just fine. Love it!
Hoobs is rpi only right? No Linux version right? For Linux, homebridge is only option I think.
As far as I know it only runs on a raspberry pi or their stand alone system. Check our their site.
Hoobs runs just fine on Linux (Debian in my case).
I thought the pi os was some flavor of Linux at its core anyway. I got lubuntu on an old mobile pentium dell netbook, 2010 era, but it does fine for kodi. Heard on reddit maybe that hoobs was way easier to setup than homebridge. So was thinking to try it but wasn’t sure about the os. Don’t use kodi often so it’s mostly just sitting idle or displaying a slideshow of family photos. Guess I’ll give it a try.
I think the Homebridge vs. HOOBs ease of use thing may have been true once. But I find either installs and runs cleanly. Where there are still issues in my experience is the plugins. On Homebridge anyway. But if you just don’t install bleeding edge versions they are usually fine.
Thx. Will probably revisit this since I now have a couple of bulbs and plugs. No real need for the cams to be in HomeKit at this point plus I’m not too thrilled to change them to the RTSP fw.
This was a great suggestion. I picked up a Raspberry pi 0 w and was able to quickly get the bulbs and plugs into HomeKit. Communication between my HomeKit devices and Wyze is working perfectly. I can now add the bulbs and plugs into my automation’s without having to call slow IFTTT integrations and web hooks. Wish there was an integration for Sense so we can utilize the motion and contact sensors.
I still hope Wyze brings native integration with HomeKit soon but this will work for now. Its a bit disappointing that Wyze will not make this happen already as its been asked for a lot and for a long time. This one size fits all approach of wanting to bring all of the devices or none of the devices isn’t great for consumers. Clearly the bulbs and plugs work fine in HomeKit. I hope Wyze puts out a mid year review to see whats coming up and we can finally see HomeKit on the list but I am not holding my breath.
I got Homebridge running pretty easily on my MacBook Air.
Not sure why you replied to my post - I think I was asking about Linux. Maybe you confused me with someone else asking about OSX.
Homebridge has multiple platform support so it can run native on OS X or can run on a RPI, etc.
I was actually asking if hoobs could run on Linux. ie - my interest is running on Linux. I don’t care about what runs on OS X, windows, chrome, android, iOS, etc.
Redhat, Fedora…Yes
https://support.hoobs.org/docs/5e8572880ab68b0344e872bb
Thanks for the link. My initial search found an faq but not the documentation. I used to run centos for my email, web, samba, ftp servers, but for my old netbook decided to try a lighter distro so now got lubuntu which is based on Ubuntu, which is based on Debian - so it should be worth a try since I think rasp is based on Debian as well. Can’t hurt to try. If not I can grab a fedora for another old laptop I got testing win10 early releases.
HOOBS makes it even easier with no web hooks. A great developer out there has been updating it lately with Bulb and Sensor support. I’ve tried the traditional Homebridge before, but it was over my head. Glad this method is more plug and play. I’m using it on a pi 0 w too.
Just adding a vote here for Homekit. I don’t mind if I need a hub. I would like to be able to incorporate the sensors to trigger events in HomeKit. I am using mostly the ikea bulbs at this point because they do work with Apple and Siri. I would like to use the door and motion sensors as triggers.
