Hi, I’ve been inching myself into building out my Wyze topography. I have a number of cameras, sensors, etc. and had successfully configured my account and two of the many devices. Worked great.
I was pulled away from the configuration with other ‘life’ issues for about 2 weeks and when my focus returned (this afternoon) I can’t seem to login using any of my devices (android or iphone).
I can successfully login to the site via web. What’s odd is that from either app I can’t seem to login or reset my password. The app simply spins and then after some time (minute or two) the rotating icon indicating that it’s thinking just stops and the page remains the same. I can repeat the process but never gain access to my mobile account.
I just noted the topic “Wyze app won’t login while on wifi” and I’ll configure my android to avoid using wifi to see if that’s the issue.
Having developed both web and mobile apps before it feels like an authentication server issue.
Any thoughts and/or help would be greatly appreciated.
Jeff
