The multi camera live view screen would solve this. The current way of the long list view would remain as an option.
<p style=“text-align: left;”>Multi cam LIVE VIEW option !!!</p>
If you print this in black plastic:
Your most of the way there?
I would love if the alert schedule included days of the week instead of just times. That way we can set it for just days we are gone at work so we don’t get alerts on our days off.
Need longer than 12 second recordings to cloud or at least fix the recording where it goes back 4-6 seconds before motion triggered.
20 second alert video, 12 second is too short, by the time an event is triggered it shuts off before you can get a clear look at who/what triggered it.
If you have a SD card and have ‘record on event’ enabled (or continuous) it will record a min of 1 minute and continue recording while any motion is present. Then you can use ‘playback’ to see that video. Also note that there is a 5 min cool down period for the ‘alerts’ but that does not apply to what is recorded on the SD card. For multiple live cam view TinyCam on Android works well.
But I agree having multiple periods per day, and for specific days of the week would be helpful, as would having playback at 2x 4x 8x speeds.
Are you saying there are compatible iOS app options that work with WYZE cameras?
