API not working
Just started this week a script I have been using for over 6 months stopped working with the following error
HTTPError: 400 Client Error: Bad Request for url: https://auth-prod.api.wyze.com/api/user/login
Wondering if something in the most recent app update changed something. Anyone else?
Just tested one of my bulbs from HomeAssistant and it’s working fine. That should use the same API. Have you updated your security token? I think they’re only good for a year.
