Any way to update the Cam 2 RTSP OTA? I already have RTSP on them but they are not where I can easily get to them physically to update.
There are only two versions and as far as I know there are no automated updates.
That sucks. The latest RTSP version works much better and works with Cam Plus
The current RTSP works with Cam Plus? It does???
I just put Pan_rtsp_4.29.4.49 into one of my Pan Cams (previously had “normal” 4.10.6.241 firmware), and it is no longer available for Cam Plus.
I then flashed one of my V2 cameras with 4.28.4.49 (previously had RTSP 4.28.4.41 firmware). It also was not available for Cam Plus.
The new RTSP firmware did for a while but they were threatening to remove it because of (in my opinion) BS performance/stability complaints. I don’t know what the current state is.
Thanks
When I first set it up it started the Cam Plus trial. I put the latest RTSP firmware on it and it’s still doing long recordings instead of the 12 second ones.
