I would like to see Alexa support for the Floor Lamp.
Alexa Integration for Wyze Floor Lamp
Note that while the Floor Lamp is not WiFi-enabled, it is Bluetooth-enabled. Alexa devices need Internet, but an Alexa-controlled device can use Bluetooth (e.g., a non-smart Bluetooth speaker). In order for this to work for a non-WiFi Wyze device, it’s going to require a coordinated effort on both ends which is unlikely.
