Aging refrigerator, powering through smart plug
Hello, I have my kitchen refrigerator plugged into a smart plug, with intent to notify me if it stops working before I replace it.
The issue I have, their are no current convenient automations for me to set this up.
My current automation is setup as follows:
“IF” Fridge has been off for 3:00hrs
“DO” Turn on Utility room cam siren
I would like to have the action option to push a custom notification, such as "Your refrigerator hasn’t turned on in the past 3hrs"or “Check refrigerator, potentially broke down”.
I think you have a misunderstanding of “Fridge has been off for 3:00 hrs” means. It sounds like you think that means that the smart plug has not detected current draw for 3 hours. That’s not what it means. It means that the smart plug has been turned off for 3 hours (which of course you would not do).
Better solution would be a temperature monitor inside the fridge and/or freezer.
As for the custom notifications, as far as I know, there is no way to do that.
I have a 20 year old Whirlpool refrigerator. I don’t use smart plugs, but have a thermometer in the freezer and frig compartments in case I lose power or the frig dies. I will always know if the food is safe to eat.
https://www.amazon.com/Refrigerator-Thermometer-30-30°C-20-80°F-Indicator/dp/B089NLQ7SF/ref=sr_1_5?adgrpid=187569907814&dib=eyJ2IjoiMSJ9.v7ze7HWpmsns-lLR3KCBI66qmX9WOijf0xd4QAvI0zRbSQKP_JI291lfIeRX7ZqJsY0-8nkoCA52CFt2LVnH52u_1vC9Ut7FblOCyc6gjzXv9BWHyOOLL3mQgq1W1DYn9tuCIQ8Bz2ImQRBbZ5n5pUi4YlkQ-erhQLp1c12mZip7VFktZ2sXii2ZXdIl6IuAwkiIfOBbnz10OmUcGc0cP7XQ0blAcnU9DbNpl2rcUE-q3252UNy1Es240-scpLU1BvaHh_PvH7OBW-Og_cYyfuOdAijo0jBvzhLdzgaM6KM.7hjk8MBgFw1ifDUG-9fwrLUa3nK3z3F_1LYN8svjQ9M&dib_tag=se&hvadid=788602035294&hvdev=c&hvexpln=0&hvlocphy=9032835&hvnetw=g&hvocijid=3473174130215267606--&hvqmt=b&hvrand=3473174130215267606&hvtargid=kwd-298631912760&hydadcr=28578_14958639_2061793&keywords=refrigerator%2Bfreezer%2Bthermometers&mcid=a9c462b4689a395687fb2989c370623e&qid=1777643780&sr=8-5&th=1
