Just installed three outdoor cams. will show live what’s going on, but with motion detection on I can’t figure out how to access what presumably is being recorded in 12 second videos to a cloud somewhere. How do I access? AND what does the icon that toggles between on, off, and auto mean? Tnx
Open the app, tap events second from the left on the bottom. Make sure you are on the correct date. On off Auto is probably the night vision setting. You have to tap on the event to view it.
Thank you. the events button appeared after i got some motions going… thanks
Some of this info may be of help too:
https://support.wyze.com/hc/en-us/sections/360011338891-Wyze-Cam-Outdoor
