My name is Hongfei, and I’m a Product Manager at Wyze. We’re exploring the idea of building a 4G LTE cellular security camera for places without reliable Wi-Fi. I have a few questions and would really appreciate your feedback.
There’s a problem with the form: Part 2, item 7 says “select up to 3” but uses radio buttons instead of checkboxes, so only a single selection is possible as a response.
I just filled out the survey and I’ve been wanting something like this to be a part of the Wyze family for a while! I want to be able to control my reserve parking spot which is a small distance away from my condo, but too far for any Wi-Fi or wiring connectivity. It definitely has to work off of battery power and solar, so being able to monitor my reserved parking space with a camera just above that space would be perfect! What makes it more perfect is being able to have all of my Wyze Cameras including a 4G LTE one on the same app! You guys have got to make this happen! So many people could benefit from this and they don’t even know it
I’m currently using over 10 wyze cameras over 4g/LTE using 4g routers to setup local networks in 5 different locations. One advantage is it allows me to use other smart devices such as switches or door locks but I would really like if I could simply pop in IoT sim cards in a camera and set it up anywhere with power wether it be wired or solar/battery packs. I don’t mind having a SIM card for each device since I’m using pooled data in Simbase IoT.
