28% On Thermostat In Wyze App
Hi Everyone,
I am new to Wyze and the first product I purchased is Thermostat. It was really easy to install. However, what i observed is in the app, I see 28% on thermostat. This hardly changes. What this number is indicating me? Can anyone help me with it?
Thanks in advance.
Regards,
Prudhvi.
Looks like it’s 28% humidity
Yup. Humidity level.
Thanks for the information @krsexton. How accurate is this? There is a difference of 4% between this and the humidifier I have?
Thanks,
Prudhvi.
Thanks for the info @Mark5. Is this accurate? There is a difference of 4% between this and the humidifier i have.
Thanks,
Prudhvi.
Mine is. You can adjust the humidity measurement in Advanced settings so they match. :+1:t2:
Thanks @Mark5. This helps.
