Added first camera without a hitch. Second camera won’t connect. Set up button pushed. Red light flashes. Bluetooth is on. Says ready to connect.
Just to eliminate it, I’d try swapping the power adapters between the cameras. I’ve had some weird issues with bad / flakey power adapters from Wyze.
I know it sounds weird since it turns on, but it helps eliminate it as a possibility.
NM I kept trying and on about the 20th time it connected. Weird.
I would still keep an eye on it. The last bad power adapter I had the camera would boot and connect and work sometimes for multiple days, sometimes for only a minute or two, then disappear again (all while looking like it was powered up).
Also double check your signal level in the app.
So far in 6 yrs I’ve not had an original camera power adapter fail. Fingers crossed and knock on wood. Lol
I’ve had four fail so far. The latest was one I mentioned above was in my garage which is climate controlled.
