On November 18, 2020, I noticed that my “Events” videos showed the time as one hour later than the actual time. The time is correct on my iPhone, so I know that is not the cause. Anyone got any idea on how to resolve this?
Thanks in advance,
Jerry
In the camera go to settings, advanced, and sync time. Should fix it.
I had one do this yesterday (or I noticed it yesterday)
We should just abolish Daylight Saving Time and it will solve the problem. (I dont really know thats what caused it…)
WHOOPS! Immediately after posting, my app prompted me to upgrade from version 4.9.6.199 to 4.9.6.218, which I did. I was then able to go to Settings/Advanced Settings/Sync Time, which solved the problem. (???)
Thanks, joedel263. I discovered your solution at the same time you sent your post. Much appreciated.
Jerry
