Is it possible to operate the wyze vac without a mobile device by just using the buttons on the vacuum?
@jeffharr Yes and no. First, the Wyze vacuum must be setup and installed on the Wyze app before it can be used manually via power button. If your vacuum is already setup just push the power button and it will start cleaning no need for the mobile device to operate it each time.
