Can it be used as a device supported in the Wyze app?
Is this something someone is selling as a pet version? Do you have a link?
Looks like a standard Wyze Cam Pan being sold by a reseller, so yep, should work with the Wyze app no problem!
I do notice it doesn’t come with a micro SD card. If you have multiple pets and want to see who left the mess on the floor, you will want a SD card.
32 GB is the standard size. Holds 3-7 days, depending on resolution set. Then it automatically records over the oldest footage.
Can it be used outdoors?
The Pan Cam is not an outdoors model, but many have used it there. It is mostly a matter of sheltering it under an overhang, or putting it in an enclosure. Obviously damage from water, etc would not be warrantied.
Thanks for your help
There was a pet store chain that was one of the first to sell Wyze gear in Canada. Markets are weird.
FYI , chewy sells several different models of wyze cams that can be used with the wyze app , including outdoor cameras, like the V3 and Wyze Cam Outdoor
