Wyze Cam v3 with Cam Plus sometimes don't upload video for events
Hey guys,
This issue has been bugging me for a while.
Have a wyze Cam v3 with cam plus subscription.
Recently, from the events tab, I would found a few consecutive events only showing thumbnails but no video, I can still go to the playback to check what happen but it is really annoying. The timeframe sometimes span for 30-40 mins.
And other videos works fine as expected. There wasn’t any correlation between when working and when not.
Steps taken but all didn’t help:
  1. Restart from app.
  2. Unplug and wait and plug back in for powercycle.
  3. Unassign/assign from cam plus.
  4. Clear cache from account tab → app setting.
  5. Both iOS app (2.36.0(14)) and the v3 (4.36.10.2864) firmware are latest.
  6. Checked wifi signal from the device info, I have 3 bars sometime 2 bars.
This cam is facing the street, so frequently I will have events with vehicles/person.
Has anyone encounter the same? And probably give me some pointer to debug.
I sent the logs to support and waiting for their reply. But just wanna try my luck with all the masterminds here :wink:
Thanks in advance.
Li
When you open these events, does it show a green question mark below the image on the right hand side?
This is a known issue with FW 4.36.10.2864
The firmware update to that version has been paused while they investigate the cause and fix it.
Note: This firmware is being paused to investigate an issue with event recording.
Yes! I do see that green question mark and that asked me to submit logs.
I would wait for the next release and update here.
Hopefully the logs I sent would help them xD.
Thanks a lot @SlabSlayer !
You’re welcome!
Here is the thread where the first reports came in and discussions on the problem.
Keep an eye on the Wyze News channel for a announcement of the next update or a fix.
