Wyze Cam v2/Pan & Wyze Bulb White Firmware Beta Test 1/5/2022
WYZE CAM V2/PAN:
Firmware Version:
  • Wyze Cam v2: 4.9.8.829
  • Wyze Can Pan: 4.10.8.829
WHAT’S NEW:
  • Bug fixes
WYZE BULB WHITE:
Firmware Version: 1.3.2.27
What’s New:
  • Improved connectivity
[Mod Edit]: Removed embedded space from version numbers to enhance search clarity.
Installed them all without issues. Tested and everything was functional.
Side note: My v2 used to have the v1 Bridge connected to it. Recently, but prior to this FW update, there was a delay in the v2 connecting. I just went through the settings and noticed the v1 Bridge Accessory was on again. I turned it off and now my v2 connects quickly without delay.
The V2 need to be updated in two steps.
From 4.9.8.746 to 4.9.8.812 and 4.9.8.829
The Pan from 4.10.8.746 to 4.10.8.829
Updated 8 V2s and 3 Pans.
1 V2 didn’t want to be updated. Tried 3 times. Tried to restart this cam within the application, Failed. Power cycling and tried updating again. Success.
All my 11 cams are online.
Are these firmwares supposed to solve the problem of offline cameras but which are not?
Yea, my v2 went through 2 FW updates as well.
Same here but everything is going well so far.
