Today we are releasing a new firmware for the Wyze Cam Pan v4. This will be a gradual rollout so you may not see it immediately.
Wyze Cam Pan v4
Version: 4.70.7.4408
What’s New:
- Improved Motion Tracking stability and camera positioning after tracking.
- Improved Timelapse download speed and reliability.
- Improved Detection Zone accuracy.
- Improved detection box display.
- Improved Wi-Fi reconnection speed when switching networks.
- Fixed an issue with Timelapse scheduling in certain time zones.
After latest firmware, cam pan v4 doesn’t detect pets or people after dark… It literally had two detections of parked cars last night when probably dozens went by.
Definitely don’t want to know about two potential hoodlums in front of my house.
Hi @Silly-Suggestions, if this happens again, could you please take a screenshot of the missed detection and submit a log right after? Please share the Log ID with us so we can take a closer look.
Also, does this only happen at night, or have you seen the same issue during the day as well? Thanks!
If it happens again? It happens all night, every night…
Please make it easier for us to revert firmware.
They know about the problem. They tried putting my camera on a new beta firmware instead of rolling it back. Now they want me to test it and give logs. It still doesn’t work and I don’t have time for that. So I just manually set it to night vision and shut off spotlight. It now detects things again. Not what I want but better than nothing.
Is it spotlight that is causing issue? I’ll try that…
AI says download old firmware from release notes, of course, we all know it;s not there.
Hi @Silly-Suggestions , thanks for providing the log!
Would you be willing to let us push a special firmware version to your device for testing? Could you also enable continuous recording and monitor whether the nighttime motion detection issue improves?
If the issue persists after the firmware update, please submit another log and share the exact timeframes when events were missed. Screenshots or video clips showing the issue would also be very helpful if possible.
Thanks so much for your help!
I found with my camera that if color vision is on at night it doesn’t detect anything. When in night vision it does but if the spot light comes on it stops following. I shut my spot light off and manually toggle night vision at night. It seems any light that makes it leave night vision will also make it stop detecting. I had a car drop someone off and it didn’t detect it because the headlights made it leave it.
I used this advice to get mine to see people at night,
I don’t know if it had also to do with Changing the spotlight detection settings. On a previous glitch, I had enabled wyze chime when it wasn’t detecting day or night.
Changes I made was auto night vision, various spotlight changes. As I thought, there are many people in front at night so testing further should be easier now that it’s detecting.
I got support to roll my camera back to 4.70.6.4312. My problems went away.
