I just purchased a Wyze Cam Pan V3. I will be using it primarily Outdoors. I know it is listed as for Outdoor use, but I would like to get a cover for it anyway to keep dirt, bird droppings, snow, ice, etc off of it. I have not found a cover online that would work for the Wyze Cam Pan “VERSION 3”.
Has anyone else found a solution for this ?
SlickWraps makes all different styles of Skins.
@SlabSlayer
Thanks Slabslayer, I’ll check these out…tlhutch4
