Wyze bulb v2 needs Alexa to be able to set night light mode
Ok, so the app has the night light scene setting that is significantly less bright then setting 1% brightness.
Why can’t this be accessed by Alexa to set the bulb to this setting?
The bulb is too bright at 1% for night light use but the night light even setting is a lot better.
Please update the Alexa API to be able to set night light mode.
Agree. Recently discovered the “night light” scene and it’s significantly dimmer than what you can accomplish on the brightness slider alone.
Either the slider needs rebuilding, or allow “scenes” to be accessible via Alexa, please.
