Wyze App 2.24+ Update
Wyze rolled out version 2.24+ Thursday 9/16/2021 which introduces support for the Wyze Light Strip models, adds new features in Wyze Home Monitoring, and makes a few improvements to Wyze Buds settings.
See what’s new in the Release Notes :
Thumbs down that the non-color bulb UI is still the clunky “new & improved” design.
Power buttons on group view screens also still problematic.
Please itemize ALL bug fixes for each new app/firmware release.
A simple link to a nested page will keep the main list clean.
Thanks! :slight_smile:
Yeah, we’ve been after that for years now. That would be cool. High-level would suffice… dun need to know anything proprietary or library build version crazy.
Although, I do think they specify when a well-known long-standing issue gets resolved.
Yup.
If this was updated concurrently with app/firmware releases it would be good:
Last timestamp to date is July 14, app v2.22 ios/android.
And because problems are often compound, these:
And because forum history, this:
Friends Don’t Waste Friends Time
I’m thinking the omission of itemized-bug-fix-detail-per-release may be a strategic decision. Maybe to avoid reproaches like:
Why’d you choose to fix this versus that, this is a much older problem, been waiting much longer than these clueless newbs, etc…
ALL THAT SAID
Virtually no griping on this release thus far, I’ll take that as a good sign… :wink:
I have the 2.24.21 iOS app and do not see the Light Strip when attempting to add a new device. I support for these supposed to be in this version, or was it removed until the product is released? Thank you!
Not sure if you made a typo… Support for the Light Strip was added to the latest iOS app version 2.24.52 which should be available to you as an update from the App Store.
Correct. I had to force my app update. Not sure why I did not see this, I usually do.
Now, I see the Strip devices.
Thank you!!
WYZE… I have to implore you once again, PLEASE revert the non-color bulb control back to its former sensible self. Simply powering individual bulbs on/off is now laborious and actually requires additional clicks within the ‘new & improved bulb bar’. Inefficient.
The entire new control paradigm is dysfunctional & silly. Please keep the app practical.
Would love to see the ability to schedule certain cameras to be on and off based on day and time. In this manner I don’t have to turn on the cameras with a shortcut when I go to bed and turn them off when I wake up and review the event logs. This has nothing to do with Cam plus which I do have . I do not have the cameras on 24 hours a day . But this is just my opinion. Thank you
The Wyze app provides you with this functionality already. Create a Schedule Rule.
In the top right, press the pencil :pencil2: icon.
Then press Edit Rules
Press the Plus + icon in the top right to create a new rule
Select “Schedule”
Name the rule, add the start and end times, select which days to run it, then press the Plus + icon next to Add Actions.
Select your cam and press the action you want it to do (on\off).
Keep pressing the Plus + sign in Add Actions to add more cams to the rule.
Yes indeed. I was assuming via the new update and such it only controlled notifications as opposed to turning on /off the camera. Thank you so very much. My apologies.
Peter
There are a multitude of actions that can be added to rules.
And just wanting to point out that the thread you replied to is announcing a version of the app that is several iterations old. The current app version is 2.33.x.
