Web Portal 2FA - unsuccessfully selecting Trust This Device every login session
Using Chrome v155.0.8059.40 (Official Build) (64-bit) on Windows 11 Business:
I am prompted to complete two-factor-authorization every time I log into the web portal. I enter the six digit code and select TRUST THIS DEVICE every time I login. However, the portal does not remember the device and requires me to complete two factor authorization at every login attempt.
How do I get the web portal to actually remember the device so i don’t have to use two-factor authorization at every login attempt?
If you are using a work computer… the 1st step would be to not use that computer. They may have policies preventing this.
The other test is to try another computer. Browsers will remember if they are allowed to remember.
I use my home computer and I have the same issue as OP. Have to log in every time and complete 2fa. So frustrating.
