Video Doorbell Pro on clearance at Home Depot for $25 (YMMV)
https://www.homedepot.com/p/Wyze-Wireless-Video-Doorbell-Camera-Pro-WWVDP-RB/318062250
If the page says “see in store clearance price” right below the price, means your store has at least one and it is on clearance. Around me it is $25, 75% off. Of course there is no guarantee you’ll be able to find it/them when you go as someone may have grabbed it or it may be hiding in over stock somewhere.
Make sure you have a store selected or the clearance thing will not show up. You can try changing to several stores in your area to see if any have it (it only tells you the status for the store you currently have selected).
Their online inventory usually shows 1 or 2 less than what is actually there. So if it says “limited stock” it probably means they have 1, if it says 1 in stock probably means 2, etc.
