V4 record with no wifi?
Might buy a v4, but wondering if it has the issue like the v3 where it stops recording to the sd when the internet/wifi stops working?
I don’t have a V4 so I can’t confirm, but @Spartan on the thread below mentioned V4 doesn’t have this issue. However, there’s no guarantee this won’t happen for future firmware updates.
Please note if you power cycle or experience power outage while the internet is down, then the camera will start recording based on the firmware build date. If you know the specific firmware build date then technically you can view it on the Wyze App. This is true for all Wyze wired cameras as far as I know.
In regards to your issue manually flashing Cam V3, make sure you are using 32GB microSD (formatted in FAT32) or smaller. You can use this sdcard.org program here. Make sure you are holding on the setup button before plugging the power back in. I would continue to hold on the setup button for 10 seconds to be sure after plugging in the power.
The V4 is fine without internet…so far.
Just one note…TURN OFF SELF UPDATE
It’s where camera info…firmware…then the update on or off switch.
I didn’t turn it off, self updated and had too much stair time…and added a few new words in my profanity lexicon…
Ya, i had to flash the firmware on 3 of my v3s i use as dash cams.
Ya, i did this to 3 v3s the other day for the ones i use for dash cams.
