Not bad. Pretty good.
25FPS is not a spec to brag about, you really think that is a significant difference over 20?
My OG and OG Tel both grab clearer pictures of plates and drivers when they’re going 25 to 30 MPH down my street AND at a sharper angle, both things which are the enemy of compression, I’m guessing that van was not going that speed in your driveway. So I can only chalk it up to user error. I guess what you’re here to say is Reolink is better for those who don’t know how to use an app?
Use whatever you want to use, if you aren’t able to do your research and determine what is best for your needs, or know how to use the app to pull a full res picture, that’s not a reason to constantly thread crap here. Just ditch your last wyze cams already, if Reolink is so much better for you, who cares if you give up a bit of time remaining on your subscription?
Video files were too large to upload to forum in full resolution but I guess you missed that point
I will stick around a bit longer now even if I remove the last Wyze cam and cancel Cam Plus Unlimited just for my Wyze Fan-Boi
I’m sorry your parents did not give you enough attention and now you have to seek it in this way.
Yet this entire thread and it’s title is just about that
When it comes to digital cameras, FPS does not necessarily translate to clearer images. But you’re just making my point, why does my 20FPS wyze cam produce clearer images than your 25FPS Reolink?
Others may disagree, that’s life…
